elecious Posted March 14, 2009 Posted March 14, 2009 hi guys, put a deposit down on a 56 2007 registered 350, which is still under manufacturer warranty just wondering what isnt covered by this that could go wrong and are these things that arent covered likely to be expensive if they break? just want the peace of mind knowing that if anything expensive breaks it'll be covered, . Quote
Ekona Posted March 14, 2009 Posted March 14, 2009 Basically any consumables won't be covered, so brake pads and clutch would be the obvious things that come to mind. Everything else is fine presuming it's been serviced in accordance with the warranty. Quote
elecious Posted March 14, 2009 Author Posted March 14, 2009 im guessing the brake pads arent too expensive to replace? what about the brakes themselves, done they cost a fortune? but the clutch going sounds like a costly job, would that be right? Quote
afterbirth Posted March 14, 2009 Posted March 14, 2009 im guessing the brake pads arent too expensive to replace? what about the brakes themselves, done they cost a fortune? but the clutch going sounds like a costly job, would that be right? Almost never discs - despite what you might be told. Clutch around £500 Get Nissan to do it; it's one of those jobs where the cost/benefit works in your favour Quote
MITZ@CougarStore Posted March 15, 2009 Posted March 15, 2009 im guessing the brake pads arent too expensive to replace? what about the brakes themselves, done they cost a fortune? but the clutch going sounds like a costly job, would that be right? A full set of pads can be had from £109.99 onwards, depends which pads you go for... Quote
SI 1 SFB Posted May 8, 2009 Posted May 8, 2009 Just had a clutch and flywheel fitted on mine, completely covered under warranty at 9800 miles!! There is hope if you push the case, I was turned down at first! Quote
Trev-the-Rev Posted May 8, 2009 Posted May 8, 2009 Service items such as Plugs, belts, etc are also not covered. Quote
flyhalfandy Posted May 11, 2009 Posted May 11, 2009 Just had a clutch and flywheel fitted on mine, completely covered under warranty at 9800 miles!! There is hope if you push the case, I was turned down at first! Clutch at 9800 miles??!! Quote
