Changing Rear Pads
nick w
Right trooops
i need to replace my rear pads, now the car is off the road until i do it so its going to be done this weekend.
The rears are metal on metal at the moment. Can some one let me know if im going to have to bleed the brake line?
any added tips? i have printed the readme from this website. any other info?
Thanks
Nick
Happy new year everyone!
Just follow the guide and be impressed with some half decent brake caliper design from Brembo. All you need to do is take the cap off the brake fluid and pad the surrounding area with rag to absorb any fluid you might push up when pushing the calipers back to get the new pads in.... ;)
Very easy to swop out Nick and no need to bleed.
Remember the copa grease ;)
It concerns me that you are down to the metal and the discs may be damaged.
If you find that they are in fact metal to metal and you require discs then just give me shout as I have plenty of preowned ones lying around ( Brembo)
Alex.
very easy job, you shouldn't have any excess fluid unless its been topped up recently, use something wooden to push the pistons back and as alex says dont forget to copper grease the rear of the pads
took me an hr to do mine all round
With Needle Nose Pliers remove pins and shims that hold pads in place.
push the pads against the piston to give you some slack and pull the pad out :thumbs:
