0nyx99 Posted April 13 Posted April 13 I understand this is a well-discussed issue, but I wish to dive a bit deeper in case anyone has come across this issue in particular. I picked up a pretty good 2005 DE GT 6 months ago. It had its fair share of wear but pretty good all round for 64k miles, it seems like the previous owner has done quite a lot of work restoring it to OEM+ and replaced a few things that were in need of replacement. This brings me to my current issue - Since purchase the clutch began slipping in 6th gear when accelerating, increasing revs with no influence on speed, then the revs drop back down and level out in accordance to acceleration. Despite this early warning sign I continued driving the car. Over the months it slowly got worse, slipping in lower and lower gears to less and less effect, unfortunately I had to drive the car and was away from my usual base of operations. The previous owner has stated that he replaced the clutch slave cylinder and replaced the lines with HEL braided lines. This leads me to believe there was an issue before he sold it to me. Early on during these warning signs, I checked the pedal adjustment, which seemed to have already been adjusted (another red flag) and the dead zone had plenty of space, so I was able to rule that out pretty quickly. Next I decided to replace the clutch fluid, thinking there may be some moisture or air in the lines meaning the clutch wasn't fully disengaging, but this also failed to produce results and the old fluid was pretty fresh. Obviously now I've let it degrade this far it's going to be a significantly more expensive fix. But that's not what I'm hugely worried about... The fact that this issue degraded at a significant rate 64k miles in with other signs pointing towards the idea this issue was present before I purchased the car, I need to figure out what the issue is before I go ahead and ruin a new clutch. Unless I'm being paranoid and its simply come to the end of its life meaning a replacement kit will solve the issue. If anyone has any ideas please let me know. Many thanks. Quote
G1en Posted April 13 Posted April 13 Sounds like its just come to the end of its life like you have stated. To be honest at 64k it may be on the second clutch in the cars life already, they don’t last as long as other vehicles but thats just a blanket statement, obviously tons of variables involved. I am on my 4th clutch in 20k miles but thats with lots of track abuse. Lots of traders on here can sell/fit or both for you a new clutch disc, flywheel, slave either separate or full kits. 1 Quote
Andy_Muxlow Posted April 14 Posted April 14 Hi buddy, if that's the original clutch it has done well. My wifes car is still on its original clutch and it is on 80,000 ish miles. Some last a lot less aome last a lot more miles. It all depends on usage really. I have known them to fail around 30-40,000 miles. 1 Quote
0nyx99 Posted April 14 Author Posted April 14 That's useful, thanks guys. Just a final note, overnight I remembered that when I test drove the car, he said something along the lines of 'you have to get used to the clutch as its a heavy duty one'. So I'm assuming he replaced the clutch. Again could just be the end of it's life as I'm unsure when it was replaced, but would that affect anything? Thanks a lot. Quote
Ekona Posted April 14 Posted April 14 Heavy duty or not, it depends how it’s been used. If abused with lots of hard starts or even if the driver slips the clutch a lot during normal driving, that can cause premature wear. Tbh given the issues you describe, I’d simply replace it and move on. Clutches aren’t that expensive in the grand scheme of things. 1 Quote
glrnet Posted April 14 Posted April 14 Sounds like the clutch has run it's course and was beginning to fail when you bought it. 'you have to get used to the clutch as its a heavy duty one'.sounds like he was spinning you a line and knew it was on the way out. Hey ho, that's life and as others have said talk to one of the suppliers on here and replace the clutch. As it's been slipping I'd be inclined to replace the fly wheel too while the box is out. Good luck with it. 1 Quote
