Pimm Posted May 11, 2008 Posted May 11, 2008 Hi, A mate of mine has just got a Z import. How can you change the trip computer to readout in MPH and not the Km/H. Thanks Quote
3FIDDYZ Posted May 11, 2008 Posted May 11, 2008 in the centre pod? If so, yes, you can, just get a UK set of guages. If on the main dials then I belive it can be done, am sure someone will have done it. Quote
Pimm Posted May 12, 2008 Author Posted May 12, 2008 in the centre pod? If so, yes, you can, just get a UK set of guages. If on the main dials then I belive it can be done, am sure someone will have done it. No sorry not the center pods ie rev counter/ speedo, i mean the trip computer near the windscreen. Quote
nixy Posted May 12, 2008 Posted May 12, 2008 if you mean the speedometer then it has to be done by a professional. You can change it to tell you the speed in MPH you are doing by just changing the front face but it will still clock up the distance in KM's. Quote
sl114 Posted May 12, 2008 Posted May 12, 2008 SHould this not have been done by the importers to pass the tests? Quote
nixy Posted May 12, 2008 Posted May 12, 2008 it has to read the speed in MPH as part of that process yes. Quote
Ardesco Posted May 12, 2008 Posted May 12, 2008 I think he means the display that shows Temp/KM per Litre/DTE/stopwatch/etc. As far as I'm aware you have to replace it to get it changed, however to give you a rough idea 8.7 KM per Litre is around 25 MPG. Quote
3FIDDYZ Posted May 12, 2008 Posted May 12, 2008 yep if its the 3 dials in the middle of the car, then yes you can just buy a UK centre pod section, plug it in and your sorted. Someone on the OC just did it. Quote
JAP350Z Posted May 12, 2008 Posted May 12, 2008 Did it last year on mine, took about 45 minutes. Only thing not working properly is the clock. OC member who did the swap said his clock worked OK. Quote
Pure Posted May 13, 2008 Posted May 13, 2008 Yep, that was me. I posted on the other forum about it :-) Clock and everything else works fine LOL. Are you sure it's not something simple on yours like just pressing the set time button to get it working? Quote
nismoip Posted May 14, 2008 Posted May 14, 2008 Hiya all Can anyone tell me where I can buy a set of these centre pods?? Quote
Pure Posted May 14, 2008 Posted May 14, 2008 Hiya all Can anyone tell me where I can buy a set of these centre pods?? The parts dept at your nissan dealership should stock them. Or keep an eye on ebay they do come up now and again. Quote
Kennydies Posted May 14, 2008 Posted May 14, 2008 OK, I know I have owned a Z for coming up 3 years but... When you press and hold the trip computer button it defaults to Time, is there a way to get it to default to another function? Quote
M13KYF Posted May 14, 2008 Posted May 14, 2008 Hiya all Can anyone tell me where I can buy a set of these centre pods?? doubt they will be cheap. Ebay will be by far the cheapest way or check out any salvage yards also on ebay Quote
