vroom811 Posted September 5, 2023 Share Posted September 5, 2023 (edited) Well the time has come to sell my cherished 350Z. I've very much enjoyed driving and working on the car but I've done as much as I’d like to her and I'm itiching to start a new project for my YouTube channel so I need the cash. £9,999 01246920239 All 44 Mods and Repairs and be seen here: https://youtu.be/cr5Vw3ZVVX0?si=3FTBNKi6L_vlhfu6 All common faults and been dealt with, the maintenance is up to date and some gentle OEM+ modifications have been completed to enhance the car. Common faults rectified include the replacement of the clutch slave cylinder, treatment of hidden rust under side skirts, replacement of rusted brake lines, replacement of rusted parts such as member supports and W brace. Full under chassis rust prevention has been performed which involved stripping the entire underside of the car. A plenum spacer has been fitted to the engine that removes the restriction of air to the front two cylinders improving performance. High flow sports cat have been fitted primarily to replace the worn out stock cats but also to increase exhaust air flow and again performance. The suspension and handling has been tweaked to get the most of the car with polybushings fitted all round, stiffer lowering springs and negative camber has been increased through front camber arms to increase cornering grip. All maintenance is up to date including spark plugs, coolant fluid, gearbox oil, differential oil, belts, power steering fluid and air filter. Videos of all repairs, maintenance and mods can be found on the Road and Race YouTube channel: https://www.youtube.com/playlist?list=PLNKrPMJBU7Wj3YyzRiHgrfwwDHX0qWRmn GT Spec Heated leather seats Factory Sat Nav Rays 18” Alloys Maintenance 14/03/2005 P1 - Oil and oil filter 9000 20/10/2006 P1 - Oil and oil filter 21220 03/09/2007 P1 - Oil and oil filter 24454 03/09/2008 P2 - Oil and oil filter, air filter, 27568 14/09/2009 P1 - Oil and oil filter 31705 14/09/2010 P1 - Oil and oil filter 35766 04/10/2011 P3 - Oil and oil filter, air filter, spark plugs 38613 21/09/2012 P1 - Oil and oil filter 41233 26/07/2013 P1 - Oil and oil filter. Coolant 43094 04/08/2014 P2 - Oil and oil filter, air filter, spark plugs 48589 18/01/2018 P1 - Oil and oil filter 71135 June 2018 – 73890 Miles Replaced both engine belts with Gates V-Belts Replaced rusted W brace with new Ultra Racing brace Replaced clutch slave cylinder and hose with Stoptech cylinder and Hel braided steel clutch line, bled system with EDC racing clutch fluid Rusted brake lines replaced. Fitted new EBC BSD brake discs, EBC Bluestuff brake pads, EBC braided steel brake hoses and bled system with EBC race DOT4 brake fluid Both rear member support arms replaced Boot gas struts replaced with SGS units September 2018 – 74657 Miles Phillips X-treme vision gen 2 headlight bulbs fitted Drivers door weatherseal replaced 6x spark plugs replaced Air filter replaced Throttle body and MAF sensor cleaned Power steering fluid changed Differential fluid changed Gearbox oil changed Engine oil and filter changed Coolant flushed and changed May 2019 – 76000 Miles Replaced front and rear anti-roll bars with Whiteline ones Replaced front and rear drop links with Whiteline ones Whiteline lowering springs fitted front and rear May 2021 – 79141 Miles Polyurethane bushings fitted to front and rear suspension, differential, subframe and steering rack Driftworks Front camber arms fitted Lower steering column joint replaced Power steering fluid changed Torqen High flow catalytic converters fitted Toyosport exhaust Y-Pipe Fitted Front driver brake caliper piston seals replaced Boot helper springs replaced Both tie rods and ends replaced Engine oil and filter changed Brake fluid changed 4 wheel laser alignment Front washer pump replaced Rusty hole under drivers side skirt treated and welded Underbody rust protection applied Motordyne 5/16 plenum spacer fitted May 2023 – 80387 Miles Engine oil and filter changed Engine remap by Horsham developments. Car now makes roughly 286 HP. Edited September 5, 2023 by vroom811 3 Link to comment Share on other sites More sharing options...
davey_83 Posted September 5, 2023 Share Posted September 5, 2023 All the best with the sale, amazingly well documented history and very much cared for. 1 Link to comment Share on other sites More sharing options...
vroom811 Posted October 1, 2023 Author Share Posted October 1, 2023 Now Sold. 2 1 Link to comment Share on other sites More sharing options...
