Traction control cutting in...
Digsy
...on full bore get aways as I change into second and floor it. This is in the dry and is not something I ever had a problem with over 3 years in the old Zed.
Is it the extra power of the MY07? The RE050s? Could be tire pressures as I haven't checked them yet.
Any one have any ideas?
We have had a couple of customers experiencing the same thing.
Seems to take a while for the tyres and shocks to bed in, has got better with miles on the car.
can't confirm for definite but the rear shocks seam to be a softer rate than previous cars.
I have this too, 04 plate!
I think it is more to do with gear change technique as if I change slightly less aggresivley then it doesnt occur.
Its odd as the power just completely cuts for a second or so, then picks up almost like the lag of a huge turbo!
I ended up working out how to change into 2nd gear properly and it went away.
Hmmm. The fact that I didn't have a problem with the MY03 suggests to me that I can change gear properly. ;)
So could I after a while, you learn not too boot it too much changing gear and when to let off the power B)
That's the perfect description. Had this in the dry on the slip road to the motorway yesterday morning - I've just moved from a turbo'd motor to the Z and it felt like the old turbo was back to haunt me(!) :scare:
Steve
the valving on all 4 shocks is actually valved stiffer than previous years, as are spring rates - at least on US spec cars.
How many miles on the car? Start with the simple things - tire pressure and alignment, and go from there
1300, mate. 19" rims going back on in the next couple of weeks so I'll check alignment/pressures and see how we go.
Thanks for the input all. :thumbs:
