ChrisB Posted April 7, 2019 Posted April 7, 2019 (edited) Used parts - Air and fuel - clearance These parts are specific to 350Z DE (JDM) £25 + p&p Airbox (28096 miles) including very low mileage Cosworth panel filter (only 4740 miles - much too good to put in the bin) Includes free gift - JDM resonated air pipe (does not include maf housing or front intake snorkel) Ideal for going back to panel filter, eg part outing an induction kit. Sold JWT pop charger kit (26230 miles, refurbed with K&N recharger kit). All kit bits are present. Only issue is that the chrome ring has got surface rust at the bottom edge and needs a refurb or covering eg with a coloured wrap? Bonus - OEM intake snorkel with already drilled mounting holes for heat shield. Includes free gift - the rest of the K&N recharger kit. Used once - approx 1/2 left. I had this on for a while between OEM and supercharger eras. Ideal for a cheap introduction to pop charging. sold Fuel pump (55483 miles) Includes free gift - Fuel bucket pressure bypass valve Removed when I put the Walboro pump in for supercharging. Useful quick fix if your pump has failed. £15 + p&p VQ35DE fuel rail, (58139 miles). Beautiful and probably worth waaaayyy more new, but it’s a bit niche. Removed as part of my CJ stage 2 upgrade. sold 6 injectors (58139 miles) Includes free gifts - plugs NGK PLFR5A /11 x 6 (platinum). Working perfectly when I upgraded to ID725. Maybe you need handy spares for testing or quickly replacing a failure. £20 + p&p MAF sensor (58139 miles). Clean and working. Removed when I upgraded to UpRev GT MAF. £20 + p&p Primary Fuel hose / damper with quick link (58139 miles) Damper, pipe and female part of quicklink were good when removed for CJ stage v.FE rails upgrade. Fuel bucket quick link piece (small pipe in this pic) sold / no longer available. £10 + p&p Secondary Fuel damper (58139 miles) As above. ..note.. fuel parts require, where necessary, replacement nitrile/viton o rings. Never use ordinary rubber. https://www.polymax.co.uk/blog/nitrile-vs-viton-what-is-the-difference Edited May 10, 2019 by ChrisB quicklink update Quote
veeg33 Posted April 8, 2019 Posted April 8, 2019 Hello, I'm assuming all bits needed for the popcharger to fit my standard DE engine is all present? All i need is just to swap parts and fit them? If yes, i'll take them. You have a PM Quote
Ava Posted April 21, 2019 Posted April 21, 2019 Hi there, Is the fuel pump still available and will it be suitable for an '04 350z? Quote
ChrisB Posted April 21, 2019 Author Posted April 21, 2019 10 minutes ago, Ava said: Hi there, Is the fuel pump still available and will it be suitable for an '04 350z? Hi, yes it is an exact replacement. Remember to buy a new fuel bucket tank grommet (eg Clark Motorsports) if you haven’t already - pretty much no chance of reusing the old grommet as they expand in an instant. Drop me a PM for more info. Quote
Ava Posted April 21, 2019 Posted April 21, 2019 10 minutes ago, ChrisB said: Hi, yes it is an exact replacement. Remember to buy a new fuel bucket tank grommet (eg Clark Motorsports) if you haven’t already - pretty much no chance of reusing the old grommet as they expand in an instant. Drop me a PM for more info. PM sent! ;-) 1 Quote
ChrisB Posted April 21, 2019 Author Posted April 21, 2019 Pump (and free gift) sold. Plenty more stuff left. Quote
ChrisB Posted May 5, 2019 Author Posted May 5, 2019 Injectors sold. Dampers, MAF, rails, airbox/filter still for sale. Quote
