370z engine noise
fuzboo
Anyone want to have a stab at diagnosing this noise (asking a lot for a video shot in a B&Q carpark I know :P ).  Idling at some lights last week I was looking around for the bus making the noise until I realised oh wait, that's me.
From inside the cab it sounds exactly like a diesel, increases with revs (clutch in or out), and is accompanied by a laboured whine when you add revs (not heard in vid, doesn't sound like a belt).  Doesn't do it from cold, only as it comes up to temp.  No other symptoms, drives OK, no noticeable power loss.  Definitely not the usual clutch chatter.
I'm wondering.. exhaust manifold?  Can't get it to a garage for a while =/
https://youtu.be/UNmn3O0Yrlk
  • 2 years later...
1 hour ago, Jimmy94 said:
Did the replacement dull the noise down? I’ve got the same on an 18 plate 18k
I wouldn't worry too much, I also suffer this. Engine will sound silky smooth but when the valve starts working it sounds awful. You can actually feel the valve opening / closing in rhythm with the noise
