Primey Posted June 14, 2018 Posted June 14, 2018 Hi all, I've recently removed the headunit and most of the interior in my Z (drift project). I've since noticed that when the car is started, the blowers seem to stay on even when switched off, and the heater comes on even though the temp is set on low. Has anyone head of an issue similar to this before? Cheers Quote
ZMANALEX Posted June 14, 2018 Posted June 14, 2018 Have you reconnected or perhaps damaged the ribbon on the module? In stock if required, if you have damaged it. Quote
Primey Posted June 14, 2018 Author Posted June 14, 2018 Thanks for the help! I may have done. It was removed initially, so the blowers defaulted to full with no lights on the button. I then reconnected the buttons and it's now playing up Quote
craigmdennis Posted June 14, 2018 Posted June 14, 2018 Definitely sounds like an issue with the ribbon connector. Removing the ribbon to get the centre console off (and having the key turned in the ignition) gives this exact behaviour. Quote
Stutopia Posted June 16, 2018 Posted June 16, 2018 Check the ribbon is reconnected properly. If it isn’t it’s likely been damaged in the remove/reinstall process. Quote
