Colin747 Posted September 14, 2017 Posted September 14, 2017 The panel gap on my rear lights seems to start off normal and then gets progressively smaller towards the rear of the car, is there some sort of rubber washer etc. that may be missing that's causing this? My car: Normal: Quote
valy Posted September 14, 2017 Posted September 14, 2017 best to check the 3 bolts that hold the light in place ,as a starting point .... Quote
Colin747 Posted September 14, 2017 Author Posted September 14, 2017 7 minutes ago, valy said: best to check the 3 bolts that hold the light in place ,as a starting point .... Could they just have been over tightened? Quote
valy Posted September 14, 2017 Posted September 14, 2017 1 minute ago, Colin747 said: Could they just have been over tightened? maybe the light was slightly misaligned when the bolts were put back on is what I can think of Quote
Sargara Posted September 14, 2017 Posted September 14, 2017 (edited) Looking at the photos Id say your light cluster is mounted correctly, as it mounts to the body and that is the part that is sitting flush. So If anything it is your rear bumper thats sitting slightly lower than it should, hence the bigger panel gap so nothing to do with your light at all. Theres a plastic clip/bolt thing that holds the rear bumper to the wing that is a right pain to unfasten, at a guess its been left undone when the bumper was off last time. (edit) This one here: https://my350z.com/forum/body-interior-exterior-and-lighting-diy/210062-diy-rear-bumper-removal-with-pictures.html Edited September 14, 2017 by Sargara 2 Quote
veilside z Posted September 14, 2017 Posted September 14, 2017 Bumper is a different height to the quarter panel Quote
colesl4w Posted September 15, 2017 Posted September 15, 2017 That gunmetal grey Z looks beaut. 1 Quote
