buzzthedog Posted April 4, 2017 Posted April 4, 2017 The boot lid on my 350z has collapsed on me a couple of times, especially in cold weather. I guess I need new struts. The existing struts are Nissan supply with no code number. Can anyone supply these? They look easy to replace. The car is 2004 by the way. Thanks David Quote
Adrian@TORQEN Posted April 4, 2017 Posted April 4, 2017 https://www.torqen.uk/nissan/350z/body-styling/bonnet-dampers/1734-350z-p2m-carbon-fiber-rear-boot-damper-p2-crhd350z-tp.html or if you want standard, get some SGS ones. Quote
Strudul Posted April 4, 2017 Posted April 4, 2017 http://www.sgs-engineering.com/car-boot-tailgate/nissan/350z Are the usual ones people go for. 1 Quote
veeg33 Posted April 4, 2017 Posted April 4, 2017 If you are feeling brave, you can try removing the boot weight first. This might help short term.....but for long run definitely get a replacement. Quote
Strudul Posted April 4, 2017 Posted April 4, 2017 ^Guide for boot weight delete. Easier and cheaper than replacing struts. Can remove the rear wiper and motor too while you're at it for extra weight saving and cosmetic enhancement. Quote
CLASSIX Posted April 5, 2017 Posted April 5, 2017 A company called SGS do uprated ones http://www.sgs-engineering.com/ they are based in Derby Sent from my iPhone using Tapatalk 1 Quote
buzzthedog Posted April 5, 2017 Author Posted April 5, 2017 Thanks for the replies. I think I will go for sgs replacements - an affordable solution! Thanks David Quote
CLASSIX Posted April 6, 2017 Posted April 6, 2017 Thanks for the replies. I think I will go for sgs replacements - an affordable solution! Thanks David I have used SGS for a few things, found them to be really good on customer service. Quote
Jk-boi Posted April 8, 2017 Posted April 8, 2017 I have some standard ones that have plenty of life in them if you want an even cheaper alternative.....I only replaced mine after fitting the nismo spoiler. Quote
