Thanks for that, very helpful. On the box that you plug the 2 white clips/wires into there is also a small red wire with a female connection, I don't know what this is for or what plugs into it, any ideas ?
Think that was for the reverse sensor, didn't bother fitting that one. Works fine without it :)
All installed and set up as per instructions, as soon as I put my key into ignition I'm getting a high pitched noise that doesn't stop, even if I start the engine, until key is removed. Any advise ?
Not heard of that happening.. If it was me I would simply unplug it from loom..put loom back to normal..start engine, see if noise gone. Then plug controler back into loom and see if it comes back ..of not, great, if it does, logic says fault with controler 🤔
