What headlamps fit?
I've got a UK (right hand drive) 350z, later, 2006 on headlamps, that has to pass a Portuguese MoT, which will require left dipping lights.
Once it has passed the lights could be swapped back.
So, do early (relatively cheap) lights fit the later cars?
Or, anyone want to swap my RHD 2006 on lights for your LHD 2006 on lights (unlikely, I know).
Or, where is the cheapest place to get some LHD lights?
Deffinately USA for LHD cheap headlights. Facelift/Non-facelift headlights are plug and play, the bulbs are different thats all.
I wish...06 onwards are all HID stock, while pre-06 can be HID or Halogen-hi beam. If Halogen it is far from plug and play (I know cos I have this crap configuration myself).
The base model with Halogen hi-beam has a 6 pin connector (as will most lights that state fitment for 05 and older), the factory HID models (both pre and post 06) have an 8 pin harness. He'll need the cheapest set of 06+ lights he can find in order for them to be plug and play, the ballasts and bulbs just get swapped over.
For me, that's these... should get you through the MOT you need.
http://www.ebay.com/itm/291133246900
Edited by Aashenfox
  • 4 weeks later...
