Transmission whine
Tomh94
Unsure which section to put this in so apologies guys, if i'm wrong could you move it?
Just wanted to see if anyone else gets a whining noise when they're cruising around 40mph plus.
I get a speed dependent whine when driving at speeds above about 40 mph, thought it might stop once I got my clutch and flywheel replaced, but I have and it isn't.
Just wondered if it was normal or not, just getting a bit paranoid!
Cheers
I would check your wheel bearings for play. I 100% thought I was getting road noise from the back wheels. ended up needing two new wheel bearings on the front. It was a whining noise that started at 40 and dissapeared at 60.
Edited by wez370
Right okay then, more expense! Cheers guys. Was on the motorway yesterday and I could just hear this constant whine all the time
I get that but only when the wife is in the car ;)
