Cro Posted July 2, 2016 Posted July 2, 2016 For some strange reason my ICT steering control loom did not come with a female plug to fit to the cars connection, just the usual 3 wires+pins needed. Any thoughts on the best solution? Could probably just place the pins into the plug but I have no idea which ones these three need to go to Quote
Cro Posted July 2, 2016 Author Posted July 2, 2016 what head unit you fitting ? Pioneer avh-x5600bt Quote
buster Posted July 2, 2016 Posted July 2, 2016 (edited) if i remember correctly you should have a wiring diagram which came with the ict kit to show you how it needs to be wired i ll have a check in my box of info sheets tomorrow to see if i can find it. Edited July 2, 2016 by buster Quote
Cro Posted July 2, 2016 Author Posted July 2, 2016 Thabks buster, I think it should have a female plug on it and be nice and simple plug and play but for some reason it doesn't. Photos from other threads certainly show theirs having a plug on it anyway Quote
buster Posted July 2, 2016 Posted July 2, 2016 here you go m8...this should help you out https://incartec.co.uk/Instructions/29-674_Nissan_noConn.pdf 1 Quote
nimz Posted July 3, 2016 Posted July 3, 2016 Did you definitely buy the Pioneer specific one? The fitting kit from incartec didn't come with the right patch lead for my Pioneer head unit. Quote
Cro Posted July 3, 2016 Author Posted July 3, 2016 Yep, or so it says on the label anyway. The link buster put up has instructions on what to do with the 3 loose wires so maybe it's normal , either way that diagram should sort me right out. Cheers buster Quote
un1eash Posted July 7, 2016 Posted July 7, 2016 My loom never came with a plug so I used scotch locks to patch into the wires. 1 Quote
GreenLandy Posted July 15, 2016 Posted July 15, 2016 Ask them why it doesn't have one? Mine didn't either (wasn't new to me though), I just soldered them onto the appropriate wires. Don't use scotch locks, they're the devil's work Quote
Cro Posted July 16, 2016 Author Posted July 16, 2016 Exactly what I ended up doing in the end, works grand thanks to the wiring diagram Quote
Stan Posted July 17, 2016 Posted July 17, 2016 Am I right in saying the link buster put up indicates the 3 loose wires have to be connected to the OBD connector? Cos I already have that split for my throttle controller and bluetooth reader. Quote
Cro Posted July 17, 2016 Author Posted July 17, 2016 No they go to the steering control look plug Quote
