GT Driver Posted May 20, 2016 Posted May 20, 2016 (edited) Not the meouw type Fitted decats this morning and took the old oem cats out for inspection. I've had a rattle at idle for the past few months and now I've confirmed a piece of the catalytic converter material has become loose within the cat housing. Picture attached- the mesh material what you can see rattles up and down. It's been fine to pass the last 3 NCTs (MOTs) as is. Question is - is there anyway to get this broken piece re-seated? Edited May 20, 2016 by GT Driver Quote
GMballistic Posted May 20, 2016 Posted May 20, 2016 If you're only using it to pass the MOT and it's been like it for the past three that you've passed then why worry about it? Either follow veilside/Rich's suggestions of a new one (used one) or just leave as is imo. 1 Quote
GT Driver Posted May 20, 2016 Author Posted May 20, 2016 Fair point GM. I don't see the decats as a very long term solution so I was just wondering if they could be repaired. But if it can't no point spending too much on a new cat. The rattle is rather annoying though: Quote
GMballistic Posted May 21, 2016 Posted May 21, 2016 Fair point GM. I don't see the decats as a very long term solution so I was just wondering if they could be repaired. But if it can't no point spending too much on a new cat. The rattle is rather annoying though: Yes that rattle is "a bit" annoying. Have you got a welder? or a friend with one? Looks like you could maybe put a mig welder gun in there just enough to tack it in place with a couple of spot welds. Wouldn't hold forever I'd doubt but if you're only putting the Cats on & off when you're getting your MOT done then I can't see it not working (imo). Quote
