350z Harness bar....!
sunnyleong94
Can't you wrap them round the strut bar? Saying that mine is stripped so doesn't have the plastics etc.
Sheet metal, not sure i would trust that in an accident.
When I was searching for harness mounting points I read something along the lines of 'I had the rear strut bar checked for strength in the event of an accident and it turned out it's far stronger than the forces that would go through it from harnesses.'
See I've started a debate.
In my case and what id recommend is mounting them to a cage / harness bar as part of a cage.
This is just my immediate solution till cage time.
Some of the 'harnesses bar' setups I've seen look weak.
Edited by cascade88
