Short Shifter issues ?
MikeyM
Alologies if posted in wrong section..Admin, please move if this is the case.
I have my 05 Z and it has a short shifter fitted and a very heavy/weighted gear knob , my issue is i am finding it very tight and on occasions a struggle to get it into gear, especially from 5th - 6th. Clutch itself is absolutely fine, its a stage one.
Is this common with the short shift ? Are they not worth having in comparision to standard ?
Thanks in advance for your responces :-)
With some shifters you have to file a small section off the shifter aperture.
However 5th to 6th is usually only a shifter plate adjustment.
This is good news.. I don't suppose there is a link of a how to etc that anyone is aware off ?
Yeah the problem I had was getting into reverse so looked where the shifter was catching an filed away it didn't solve it 100% but just using the shifter it filed it away by itself. It does sound more like the shifter plate isn't aligned right if it's 5th to 6th
