Help! Clouds of smoke - blue / black / white
Hi all, 2 weeks ago my car started feeling different. It then went on to produce clouds of smoke (white when cold and blue when warm). The car stinks of oil in the cab when stopped.
I had to change spark 4 plug due to it starting to misfire and also changed to HFC.
I'm thinking that it could be valve stem oil seals that have gone. Is this a common problem with 350z at 100k miles?
Any other ideas??
I can't find any how to's on how to remove both heads or anything about valve stem seals going so I'm thinking maybe it's another issue.
If it was a head gasket I'd see residue on the cap but that is clean and the oil I drained out is still good.
Any help welcome. This is on a 2004 DE uk car
How much oil are you using per 1000 miles ?
Please don't come back here and say that you have not checked it .
Why did you drain some of the oil out ?
It was using around 3/4 - 1 litre per 3000 miles but now estimated 1 litre per 500-1000 haven't driven it very far since it started.
I drained some oil around a litre just to check for metal fragments/ milky then topped back up.
Check the valve in the cam cover.
If you have wear causing the oil emissions and it is valve stem oil seals or rings or pistons.
Then you have two options:
Rebuild the engine or fit a known replacement pre owned engine.
Trust they are a garage that knows 350's well as we have seen far too many bad feedbacks from members about garages basically miss-diagnosing.
You would be best off using an independent that specialises in the ZEDs if possible - if you post up your location (or better still add it to your avatar), then I'm sure you will be pointed in the right direction.....if necessary ;)
