Make sure the working fob is no where near the car when you're doing it as that can confuse things
Sent from my HTC One using Tapatalk
  • 4 months later...
Just did this as my plip had stopped working remotely. I was only able to get it to work with the drivers door open.
If anyone in the west midlands is having trouble doing this, I be more than happy to lend a hand.
David
  • 2 years later...
David
Reviving an old thread.. I've had an issue with trying to register my key since i got the car :(
Got they key tested, no signal from it, changed battery, still not signal. Bought a new key from ZMANALEX, gave a signal.
I tried the programming procedure but still doesn't register the key. The hazards flash twice to enter programming mode. However, when I hold the unlock and press the lock button then release, nothing happens. I've tried all the possible combinations. I then proceeded to replace the receiver in the car behind the passenger dash hoping that would be the issue. Nope, still the same issue.
I have a 2004 GT Spec UK model 350z.
1 Working Valet key with no lock/unlock button
1 Non working square key with lock/unlock buttons. - The car starts just fine, just cant register the key to use the remote unlock feature.
Any help would be appreciated.
