MattRwebB Posted July 16, 2015 Posted July 16, 2015 Anyone recommend some DRL front bumper Reflectors ? don't want to buy some that are not bright in the day time and end up not working after a while Quote
veeg33 Posted July 16, 2015 Posted July 16, 2015 Not too clear from you profile picture, but it looks like a HR zed. Try EBay, that's the best place to start. I think they are around £100 per pair. Its plug and play, just need to wire it up. However, from my understanding, to pass MOT, your DRL must be switched off or dimmed when your side lights and main beam is switched on. You can buy a controller to dim that for you. Its around £6 (Ebay) for that controller and just need to tap into your existing wiring and its pretty straight forward. Tarmac Sportz a trader here do them DRL reflector covered in Carbon Fiber but not sure if he still have them or not. Worth PM him. Also there is a guy in the USA --> www.zledslights.com Pretty good but not cheap. I ended up making myself a DRL with both white and amber (signal light). Overall pretty good apart from the controller not doing its job 100%. The controller is suppose to switch the white LED off completely when i indicate left or right, but i think the relay somehow managed to switch the white lights on every now and then hence when I indicate, its flashing amber and every now and then the white will flash too. Apart from that, its great IMO. Check out my build thread in my signature below. post #97 onwards for my DIY DRL project. Quote
MattRwebB Posted July 17, 2015 Author Posted July 17, 2015 Yh I have the HR I don't suppose it matters what drl I get as long at the fit a 350z ? Sent from my iPhone using Tapatalk Quote
veeg33 Posted July 17, 2015 Posted July 17, 2015 Reflectors on the HR and DE are different, so you'll need to get those that will fit your HR bumper if you are thinking of replacing current reflectors to DRL reflectors. Mounting points are not same. HR reflector points more towards the front of the zed, whilst DE more to the side (not very visible on the front). Quote
ilogikal1 Posted July 17, 2015 Posted July 17, 2015 Wait a second: you want DRL reflectors and DRL headlights? Save yourself the bother and just hang a string of fairy lights off the front of your car instead. 1 Quote
MattRwebB Posted July 17, 2015 Author Posted July 17, 2015 Just waiting for Xmas eve buddy 😇 Sent from my iPhone using Tapatalk Quote
