nigess Posted July 13, 2015 Posted July 13, 2015 I have 15mm front and 20mm rear wheel spacers going on tomorrow. Does this affect anything other than the looks? Quote
Zeezeebaba Posted July 14, 2015 Posted July 14, 2015 Wider track may increase the tramlining effect off camber with road imperfections etc may pull either way to be fair. 15 and 20 set up shouldn't be to much of an issue. Probably better answered by someone who has the same set up tbh. Quote
Rock_Steady Posted July 15, 2015 Posted July 15, 2015 15 on the front may cause a close call on the inner arch lip, depending on what type of wheels you've got. When I was running standard wheels I had 10mm on the front and that was close. Quote
bamdc2 Posted July 15, 2015 Posted July 15, 2015 I ran 20mm all round with zero issues. Had a 4 wheel alignment after new tyres as well and car felt really good. Sight tramlining but only very rarely, I actually preferred the way the car felt. Great mod and really makes the RAYS fit the arch much better Quote
Tinyflier Posted July 15, 2015 Posted July 15, 2015 I ran 20mm front and 25mm rear with standard Rays/tyre sizes and it was perfectly fine with regards to arch clearance so you shouldn't have any issues with the sizes you are using. As others said you might get a tiny amount of tramlining but within a few miles you will have adapted to that, a 4 way alignment is always a good idea if you haven't had that done lately. David Quote
nigess Posted July 18, 2015 Author Posted July 18, 2015 Thanks for replies. Had spacers fitted looks good n steering issues. Cheers Quote
bamdc2 Posted July 20, 2015 Posted July 20, 2015 would strongly recommend a 4 wheel laser alignment. The Zed really suffers if you haven't got the tracking right and for the sake of a few quid its worth it. Quote
