Sammicd Posted June 29, 2015 Posted June 29, 2015 Hi all, Help! Just had a complete regas , they checked the system and said all was good with no leaks. Worked well and Blew cold for a few hours before blowing warm again. Any ideas guys? Or did they just not check it properly 1st time? Thanks Sam Quote
dann2010 Posted July 2, 2015 Posted July 2, 2015 Check your heater settings first bud If all seems fine then take it back Sent from my GT-N7100 using Tapatalk Quote
veilside z Posted July 2, 2015 Posted July 2, 2015 Start the car up in idle position then hit the air con on. The rev counter should raise the revs slightly. This will determine if the system is operating correctly first. Quote
gareth29 Posted July 2, 2015 Posted July 2, 2015 they cant know there isnt a leak unless theyve checked for one - it sounds like a leak - can they tell you how much refrigerant they took out before they refilled it then compare that with whats left when you take it back in Quote
Keyser Posted July 2, 2015 Posted July 2, 2015 Could be the compressor is a bit weak or the pulley isn't engaging correctly, the pulley has a slip release system to reduce drag at high RPM. Just a thought - I have a spare one laying around if you want to swap it to test that theory Quote
veilside z Posted July 2, 2015 Posted July 2, 2015 (edited) He said initially they checked it. (The system) Edited July 2, 2015 by veilside z Quote
Sammicd Posted July 8, 2015 Author Posted July 8, 2015 Thanks Guys, I took it to a specialist and they found a small hole in the condenser. All working now! Samantha Quote
