Help - Battery Flat And Key Won't Turn
Jabbah
My battery has gone flat and so the central locking won't work, but also when I put the key in the drivers side lock I can't turn it to unlock the door to open the bonnet to charge it. What can I do? Is there a way to pop the bonnet to connect a charger?
There's definitely a bit of play in it, I've tried squirting some WD40 through whatever orifice I can find so will let that soak in. Feels more like the wrong key, don't think I ever tried it since I had it.
If push comes to shove, the bonnet release cable is situated at the top and behind the R/H/F arch liner.
Giving it a gentle tug with some one pressing on the bonnet nib should release the bonnet to access the battery.
