oil pressure high? (sensor possibly?)
Posted (edited)
Hi guys I haven't often paid attention to the oil pressure but recently on cold starts the needle goes right round too max at 8KKPA it'll bounce between 6-8 anytime I go over 2.5-3k revs until it's warm, once she's been running it goes back to normal!
is this normal or should I replace the sensor?
Edited by Hughesie90
If the oil level is fine, and the pressure reads somewhere over 0 on the gauge, then every thing is fine. :)
Even like 1mm over 0? thats what mine does, well, done lol.
  • 1 month later...
Posted (edited)
Hi Guys,
I have a similar problem were the gauge shows 60 psi on ignition before the engine is started and then rises to 120 psi as soon as I start the car. I have given it to a local garage who has replaced the sensor with a working one from a 350z which was being stripped for parts though it still has the same problem. Is there a possibility that it could be an issue with the wiring instead of the sensor?? I have looked on many posts but every time it points to the oil pressure sensor. I find it hard to believe that the replacement sensor decided to break between being removed for the original engine and being fitted in mine.
Any ideas would be much appreciated!!
Edited by mje-87
