Watermarks on Headlining Board - help in removing ?
Hello There
Can anyone advise how I can remove some large watermarks on the head lining board of my 350z ? Its not bad but I notice them - watermarks caused by leaking rear window washer... :shrug:
Reading on other forums the advice given is to use :
- using tent cleaning fluid.
- Autoglym interior cleaner.
- Actually steam cleaning (gently) the watermarks off.
Any specific cleaning products / techniques / advice would be great appreciated.
Thanks.
I normally use a hand held steam cleaner. However this may only spread the stain if it's contaminated with screen wash. A steam clean with plenty of dabbing via absorbant paper towels might work ok.
The trick is not to over-wet the area.
I just use an interior cleaner; lightly sprayed onto a small area, worked in with a damp (not wet!) microfiber cloth and then wiped dry with another clean, dry microfiber cloth.
