Mishimoto oil cooler - does it actually work?
I see Torqen/Octet has one of these for sale and I was wondering if anyone had it fitted the Mishi to a 370ZN (or post 2012 370Z) and witnessed a noticeable improvement in temp stability and cooldown times? Seems to be a bit of a weakness with the OEM design and I see some US franchise dealers fit uprated coolers as an official $800 option!
Cheers,
DT
Yep definitely works. I would get one with a Thermostatic plate though if yours is a daily.
Normally the thermostats let the oil flow through the cooler at 85 degrees.
Most aftermarket oil coolers are essential for the 370z if you planning to take it on track as the oil temp jumps to 120 after a few hot laps at kh. Now l can do almost double the amount of laps and it sits around 90 on the back roads during a hot day.
Agreed. I managed 8 laps of Combe until the car limited the revs for me.
