*** TORQEN *** 350 DE & HR Air Intake kits
1. 350z DE AAM Competition Angled Intake Plenum Spacer
The AAM Angled Plenum Spacer for the G35, 350Z & FX35 is the ultimate upgrade in the quest for more power. THIS IS OUR MOST POPULAR UPGRADE FOR THE VQ35DE - AND THE BIGGEST HORESPOWER GAIN FOR THE MONEY! The billet aluminum spacer sits between the factory upper and lower plenum, creating a larger volume to rush towards the cylinders. Power gains across the board. The upper RPM range opens up considerably. You get to keep your factory engine cover, your factory strut bar (350Z) and gain 10-15HP in under an hour. 2006 350Z/G35 gain between 6-10hp on average.
Features:
• Proprietary ANGLED Design Provides Additional Air Flow to the Front Cylinders
• Retains Factory Strut Bar (350Z) and Engine Cover
• Stock-like Appearance
• Custom Cut In House on Our CNC Mill
• Easy Install and Removal
• Built with Strong and Lightweight 6061-T6 Aluminum
Package Contents:
• AAM Spec Angled Plenum Spacer
• All Bolts Required for Securing the Plenum
• Modified OEM Gasket to Reseal the Top Plenum
• Spacers for the Strut Tower Brace
• Detailed Directions
£199
2. 350z DE AAM Competition Throttle Body Spacer
The AAM Spec. Throttle Body Spacer is a great addition to any upgraded 350Z. Each AAM Spec. Throttle Body Spacer comes pre-tapped with three vacuum ports. This saves both time and money when running vacuum lines (no need to tap the factory intake plenum with this spacer). Because you have more vacuum ports available you can run components seperately (ie. map sensor, boost gauge, fuel pressure regulator, boost controller, etc.) which improves both their performance and reliability. This will fit any VQ35DE engine.
£109
3. 350z DE AEM Cold Air Intake
A Cold Air intake system relocates the filter outside of the engine compartment to deliver the coolest air inlet temperatures possible. Cooler air carries more oxygen, which translates into a more intense explosion in the combustion chamber to create more horesepower and torque. But that's only part of the power equation. Tuning the inlet pipe in length and diameter to match the engine's resonance helps move more air to the cylinders (think of your engine as a big air pump), and no company on the market can tune an inlet as well as we can. We also monitor fuel trim correction factors and all OBDII sensors during R&D to eliminate leaning the engine out and/or throwing a check engine light.
Our Cold Air systems are dyno-proven and tested against the competition to create more useable power than any other system of their kind. Every AEM Cold Air induction system features the highest standards of construction and we are so confident in their fit and performance that we guarantee them for the life of your vehicle. All AEM Cold Air systems are either 50-state legal or pending (excluding "Off Road" and "Hybrid" systems), include a lifetime DRYFLOW Synthetic air filter and come with a limited lifetime warranty.
• Outperforms every other Cold Air system on the market
• Manufactured and assembled in the USA
• Inlet constructed of lightweight aircraft aluminum and mandrel bent for maximum flow
• Reinforced TIG-welded brackets and fittings deliver added durability
• Utilizes a complete hardware kit with soft mounts for a guaranteed perfect fit
• AEM?s lifetime DRYFLOW Synthetic air filter is 99.4% efficient, filters to one micron, and never needs filter oil!
• Comprehensive installation instructions, decals and license plate frame included
• Available powdercoated in red, blue or silver, or with a mirror-polished finish
• Guaranteed for life
COLOUR: blue, red, silver
£299
4. 350z HR AEM Dual Inlet Cold Air Intake with heat shields
A cold air intake system relocates the filter outside of the engine compartment to deliver cool air inlet temperatures. Cooler air carries more oxygen, which translates into a more intense explosion in the combustion chamber to create more horsepower and torque. But that's only part of the power equation. Tuning the inlet pipe in length and diameter to match the engine's resonance helps move more air to the cylinders (think of your engine as a big air pump), and this tuning allows us to deliver large power gains. We also monitor fuel trim correction factors and all OBDII sensors during R&D to eliminate leaning the engine out and/or throwing a check engine light.
Every AEM cold air induction system features high standards of construction and we are so confident in their fit and performance that we guarantee them for the life of your vehicle. All AEM cold air systems include a lifetime DRYFLOW synthetic air filter and come with a limited lifetime warranty.
COLOUR: Silver, Polished (£15)
£399
5. 350z DE AEM Short Ram Intake System
AEM Short Ram intake systems are an economical alternative to our Cold Air systems and deliver the best performance, value and ease of installation than any other short inlet intake. Our Short Ram intakes install easily under the hood and cost less because we use less material to manufacture them.
During the development process, we found certain applications respond favorably to shorter inlet lengths over our longer Cold Air designs. For these applications (denoted in the search results page), we offer a Short Ram system only. We perform extensive temperature testing to locate the filter in the coolest area of the engine compartment, which allows our Short Ram systems to achieve the lowest inlet temperatures possible. Please refer to our temperature testing procedures for more information.
COLOUR: Red, blue, polished
£279
6. 350z DE aFe Power MagnumFORCE Stage-2 PRO 5R Intake
Enclosed in a durable 16 gauge, powder-coated heat shield; this air intake system features a washable/reusable conical air filter that improves airflow for increased horsepower and torque. This intake system also features a heat-insulating molded plastic tube that replaces the stock intake tract and directs increased air flow with improved volumetric efficiency for maximum performance. One-piece heat shield requires little or no assembly and the filter is constructed with 100% polyurethane for long life and multiple cleaning cycles.
£289
7. 350z HR AFE Takeda Stage-2 Pro Dry S Intake System Polished
The Takeda Retain Intake is a short ram dual air intake intake system. In recent testing this intake produced 9hp and 8lbs. x ft. of torque. Takeda intakes are constructed out of lightweight clear-coat anodized tubing for maximum air flow and a great style. Each intake uses a large 360 degree high flow PRO Dry S air filter for maximum flow, filtration and convenience. The PRO Dry S air filter requires no oils and cleans with simple soap and water. Takeda intakes come complete with all tubing, filters, couplers and hardware for an easy installation.
Quick and Easy Installation:
Complete installation in 40 minutes or less.
Cleaning Convenience:
This system includes a Pro DRY S oil free synthetic air filter which will never require to be oiled after cleaning.
Clear-coat Anodized Tubing:
Prevents intake tube discoloring and oxidation.
£329
8. 350z DE Berk Technology Aluminum Z-Tube
Aluminum Z-Tube. Direct replacement for the 350Z rubber intake tube. Can be used with stock air box or aftermarket filter. Polished 6061 Aluminum. Includes custom made Thermal Flex silicone couplers & OEM Tridon stainless steel marine grade hose clamps.
£109
9. 350z DE Greddy Air Intake System
GReddy Air Intake System with dual polished Aluminum piping (with MAF attachment point) to a single (dual inlet) dry element, filter.
Like our exhausts we carefully study each specific application to develop the ideal system; complete, easy to install, with quality construction and great fitment. GReddy Air Intake systems improve horsepower through a cool air-charge and smoothly increasing intake air-flow. Our new 4-layer synthetic, deep pleated, dry filter element provides improved filtration, with long service intervals. It also provides high flow, but without sensor contamination. Manufactured and designed in association with aFe Power, for USA spec vehicles. Performance gains are attributed to the use of our application specific filter heat-shields, air-box covers, or our new Momentum series high flow, sealed air-boxes.
£199
10. 350z DE HKS Racing Suction Reloaded Intake Kit w/ Heat Shield
HKS Racing Suction Reloaded Kits have been developed as the leading intake system for high performance applications. Each kit features aluminum suction pipes that have been tested for optimal air flow. Included in each kit is HKS' Reloaded filter (BLACK) with its patented Super-Funnel and new technical advances:
• Filter cage allows for 30% more intake surface area
• Aluminum back plate for added strength
• Sealing ring reduces contaminants from entering engine
• Dual Density wet filter element
£399
11. 350z DE Injen Cold Air Intake
New Injen Cold Air Intakes are the newest true cold air intakes on the market. With a 4HP gain to the wheels, these intakes are remarkable. Injen intakes come with a stainless steel heatshield which prevents heatsoak from the engine, and also a filter with a built in velocity stack for increased performance. All other nessessary hardware is included for complete installation.
Colours: black, polished
£239
12. 350z HR Injen Twin Short Ram Intake System
The launching of a new era of sophistication begins with the all new SP1988. Combining their patented and renowned step down process, the patent pending Air Fusion, the Injen/AMSOIL dry filters and for the first time ever, "Air Intake Horns" proved to be an explosive combination. Injen didn't stop at creating the best and only dual cold air intake system for the 350Z, at Injen, they committed themselves to engineering the first twin, short ram intake system that continues to build usable power throughout the power band. Injen Technology's award winning innovations are what allows them to maintain a leadership position while competitors attempt to follow Injen's bench marks.
£309
13. 350z HR Injen Dual Cold Air Intake
The SP series is a cold air intake system for the enthusiast craving mid-range power. The intake tube is strategically placed behind the front bumper to acquire colder, denser air. Every SP system is certified or pending by the California Air Resource Board and backed by Injen Technology's limited lifetime warranty.
Injen's 350Z air intake system is the "First and only" True Cold Air Intake. Guaranteed to produce Massive Power Gains of up to 16 Horse Power and 16 Torque. With these unmatched power gains, Nissan owners will be burning up the track and flooding the chat rooms with their new track times. This is the first of a series of kits to be released using both MegaRam Technology and the all new Air Fusion.
Note: Air Fusion (Patent Pending) - Engineered to stabilize short term and long term fuel trim levels.
£449
14. 350z DE JWT Pop Charger Intake Kit
JWT Pop Chargers for the 2003-2006 350Z. POP-Charger air filters are designed for maximum air flow by using a 6" diameter venturi surrounded by an oiled gauze filter element. The filter element is reusable after cleaning and reapplying filter oil. POP-Charger aluminum venturis are made from lightweight cast aluminum and CNC machined by us to ensure a quality fit. Product comes with Intake, Adapter, Heat Shield, and Bracket. HP Gains are around 11-12 at Crank, and 6-7 RWHP, and you'll notice a nice new aggressive sound from the engine.
£129
15. 350z HR JWT Dual Pop Charger
In 2007 Nissan drastically improved the VQ35 intake system by adding an extra throttle, so the question was, is there any room for improvement• After a full year of testing JWT got the answer, "YES", but only with the most efficient Pop-Charger Venturi inlets and hood-sealed heat shields. In addition to a 6.5 to10 WHP improvement, the tone of the engine due to the dual 6• venturis is definitely the most beautiful sound ever heard from a VQ engine!
£329
16. 350z DE Motordyne Engineering 5/16" Copper Iso Thermal Plenum Spacer
This is the 5/16 Stealth Plenum Spacer Upgrade for the 03-06 350Z, 03-06 G35 Sedan, and 03-07 G35 Coupe VQ35DE Engines. Gains from 12-14HP, simple and easy install. Works with OEM Strut Bar and Engine Cover. Iso Thermal Spacer Reduces Heak Soak and helps prevent power loss. Iso Thermal Gasket also allows upper and lower plenum to run cooler. Copper Throttle Upgrade Recommended for areas that have Heavy Snow Fall or Salt on roads.
£239
17. 350z DE Motordyne Engineering 5/16" Basic Plenum Spacer
This is the 5/16 Stealth Plenum Spacer Upgrade for the 03-06 350Z, 03-06 G35 Sedan, and 03-07 G35 Coupe VQ35DE Engines. Gains from 11-13HP, simple and easy install. Works with OEM Strut Bar and Engine Cover.
£169
18. 350z DE Motordyne Engineering 5/16" Iso Thermal Plenum Spacer
£199
19. 350z DE Motordyne Engineering Copper Iso Thermal 5/16 Spacer and MREV 2 Lower Intake Manifold Plenum
The Motordyne MREV+ lower collector! A universal stealth mod for use on any 350Z. When used with or without a spacer or aftermarket plenum, this modified lower collector will make substantial power gains.
Multiple independent test show when used with a 5/16" spacer on the REVUP engine, the combination will add at least 15+ HP and 18+ TQ in the upper midrange. Many independent REVUP tests have dynod in excess of 20HP and 30 TQ in the upper midrange and with high RPM peak power increased by 3-5 HP.
On the road course or drag strip this lower collector adds substantial HP and TQ. No other normally aspirated VQ modification provides as much gains as MREV 2!
£649
20. 350z DE Motordyne Engineering MREV 2 Manifold
This is a upgrade to the MREV package.
By machining the lower collector intake runners 1&2, it allows for more flow above the most critical area without significantly changing the optimized plenum internal volume. This provides even greater MREV system performance by maximizing both torque and horse power. No other NA VQ modification provides as much gains as MREV Plus!
£439
21. 350z DE Nismo R-Tune Cold Air Intake
The Nismo Cold Air Intake is now available for the 350Z. The System will add a 5.5 HP increase at the rear wheels by using a denser, colder air intake. Mandrel-bent 3" tubing maintains consistent inside diameter. The System also comes with a Bypass Filter Designed to prevent inadvertent water ingestion. The filter is reusable and washable. The System is a direct bolt on, with complete instructions.
£269
22. 350z HR Nismo Dual R-Tune Intake
• 10.2 HP and 8.0 lb-ft increase at rear wheels
• Intake length and diameter tuned for maximum performance
• Designed on the dyno for real time power gains throughout the range
• Powder coated heat shields
• Mandrel-bent 2.75• diameter tubing maintains consistent inside diameter
• 6061 aluminum tubing material
• Tube brackets soft mounted to the heat shields for optimal fitment
• Reusable/washable intake air filters
• Precise, bolt-on installation
• Provides a more aggressive intake sound over stock system
• Powder-coated black finish with NISMO logo
£399
23. 350z HR Stillen Generation 3 Ultra Long Tube Dual Intake Kit
The new Gen 3 Ultra Long Tube Intake places two large K&N filters in front of the radiator and directly behind the main grille. Strategic placement of the filters allow for optimum cold air flow and easy filter removal for cleaning. It features additional polished tubes that pass through the front core support, larger air filters than the Generation 2 unit, a urethane splash guard to help protect the filter and a system of varied diameter tubing and steps to maximize air velocity.
The power result: A dyno-proven 20 horsepower gain at the wheels on the Dual Throttle Body 350Z, 18.5 horsepower gain at the wheels on the G37 Coupe and 17.5 horsepower on the 370Z. This translates to an estimated 20-22 horsepower gain at the flywheel! For G37/G35 Sedan owners, gains are 14 horsepower at the wheels. No other intake for the VQ can match these power gains!
Recommended installation requires removal of the front fascia clip (not absolutely necessary, but significantly aids in ease of installation) and slightly enlarging the holes through the front core support. Installation time is estimated at two hours for an experienced technician. No other part relocation or parts removal is required.
£489
24. UpRev 70mm MAF Flange
Used for fabricating custom aluminum MAF tubes
£39
25. 350z DE Weapon-R Dragon Cold Air Intake
Weapon-R Dragon Intake Systems are one of the mostly highly rated intake systems in the world. Used in many countries in many different forms of racing. Also recently rated "Best Overall Performer", outperforming Cold Air & Short Ram Intake systems, in the 2003 Tuner Performance Reports, Intake system Battle.
Our Intake Systems are CNC Mandrel Bent out of 6061 aluminum, and then Hand Tig Welded to ensure a positive seal and proper fitment. Each one of our intake systems is carefully tuned, by matching the engines displacement, air intake capacity and airspeed to the intake systems tube size and length, maximizing every engines performance output. This Intake is matched with our World Famous Dragon Filter, which provides maximum airflow, with the protection of high quality dense Poly Urethane Foam. Many studies have shown Flow rates of up to 80% more Air and Better Dirt Filtration with Foam Filter than the conventional cotton filter.
The Dragon Filter features a Computer CAD Designed and Flow benched Tested Velocity Stack, which greatly increases airflow and air volume into the engine, therefore increasing engine performance. Another one of the Dragon Filters positive features are the capability to be disassembled to be cleaned and then re-assembled after cleanings or to change the color of the foam filtering element.
Colour: Black foam filter or Blue foam filter
£229
26. 350z DE Weapon-R Secret Weapon Cold Air Intake
Nissan 350Z 2003-2006, Secret Weapon Air Intake System by Weapon-R®. The Secret Weapon Air Intake System uses patented technology to feed the engine 3 times as much air as other systems. As a result, engine performance is increased more than with any other system available.
Features:
• Patented technology increases airflow 3 times more than conventional systems
• Each system is tuned to maximize engine performance output
• Every system includes the revolutionary Secret Weapon Air Filter
• Dyno-tuned air intake pipe constructed of CNC mandrel-bent 6061 aluminum for smooth airflow
• Comes complete with all necessary mounting hardware and comprehensive installation instructions
• All Weapon-R foam air filters are backed by the Weapon-R Million Mile warranty
To create an air intake system with the highest airflow possible, the engineers at Weapon-R experimented with basic laws of physics. They found that by creating two different air velocity profiles in the intake tube, both traveling at different speeds, it increased overall air speed and volume to the engine, naturally feeding the engine 3 times more air than a conventional air intake system. To implement this patented technology, Weapon-R CNC mandrel-bends 6061 aluminum to the desired shape, and then polishes it to a show quality finish. The intake tube is then matched with Weapon-R?s Secret Weapon air filter. The Secret Weapon air filter features a tuned velocity stack to increase velocity and decrease turbulence. The dramatic increase in airflow results in a greater increase in engine performance than would be possible with any other air intake system.
Weapon-R® Ram Air Kit II turns your air intake system into a Ram Air Intake. The Ram Air Intake brings cooler air to your intake system. Cold air is denser and contains more oxygen and cooler engine air inlet temperatures result in more power. Furthermore, the Ram Air tube is made from a high temperature fire resistant plastic, to resist heat soak which robs horsepower from your engine. The Ram Air Kit is easy to install. Just connect the hose to the top of the air filter, mount the velocity stack in the lower part of the grille and attach the hose.
£279
27. 350z HR Weapon-R Twin Throttle Body Secret Weapon Intake
To create an air intake system with the highest airflow possible, the engineers at Weapon-R experimented with basic laws of physics. They found that by creating two different air velocity profiles in the intake tube, both traveling at different speeds, it increased overall air speed and volume to the engine, naturally feeding the engine 3 times more air than a conventional air intake system. To implement this patented technology, Weapon-R CNC mandrel-bends 6061 aluminum to the desired shape, and then polishes it to a show quality finish. The intake tube is then matched with Weapon-R?s Secret Weapon air filter. The Secret Weapon air filter features a tuned velocity stack to increase velocity and decrease turbulence. The dramatic increase in airflow results in a greater increase in engine performance than would be possible with any other air intake system. Every Secret Weapon Air Intake System comes with everything necessary for installation including comprehensive instructions. Weapon-R® Ram Air Kit II turns your air intake system into a Ram Air Intake. The Ram Air Intake brings cooler air to your intake system. Cold air is denser and contains more oxygen and cooler engine air inlet temperatures result in more power. Furthermore, the Ram Air tube is made from a high temperature fire resistant plastic, to resist heat soak which robs horsepower from your engine. The Ram Air Kit is easy to install. Just connect the hose to the top of the air filter, mount the velocity stack in the lower part of the grille and attach the hose.
Features:
£359
28. 350z DE Weapon-R Nissan Neo-Ti Finish Secret Weapon Air Intake System
£269
30. 350z DE Apexi Power Intake Panel Filter
This is a direct replacement for your stock air filter and you can retain the stock air box. The high flow filter used by Apexi will improve throttle response and are maintenance free for up to 15,000 miles.
£25
31. 350z DE Blitz SUS Power LM Panel Intake Filter Replacement
SUS Power LM panel filters are direct replacements for the standard panel filter, they fit straight into the standard air filter box and improve airflow into the engine whilst still offering very high levels of filtration.
£39
32. 350z DE Stillen Hi-Flow Intake Kit
The first step in upgrading your car's performance is to replace the restrictive stock air box with a STILLEN Hi-Flow Intake.
Additional air flow increases the engine's efficiency and power output by increasing the quantity of the air/fuel ratio. The STILLEN Hi-Flow consists of a precision machined ring and a gauze element (cleanable) filter. Like a velocity stack, the ring uses the venturi effect to accelerate air intake speed.
Power and throttle response will improve throughout the entire RPM range. Your best dollar-per-horsepower investment by far! Most people find the authoritative note of the intake pleasing, but note that increased noise levels result.
£219
Edited by octet@TORQEN
  • 1 month later...
  • 3 months later...
