GT Driver Posted February 10, 2015 Posted February 10, 2015 (edited) fitted a new LED number plate bulb earlier - turned on the lights parking only and the lights quickly flicked off. number plate lights, rear lights and front side lights are now not working. Have I blown a fuse? Brake lights and others are fine. Any idea where this one is located? Presumably the 'hidden' one behind the battery? Edited February 10, 2015 by GT Driver Quote
Keyser Posted February 10, 2015 Posted February 10, 2015 Off the top of my head that fuse is in the panel to the right of the throttle pedal - But I could be wrong in which case it is in the panel behind the battery so lets hope I'm right as the other one can be a pain to get to Quote
buster Posted February 10, 2015 Posted February 10, 2015 (edited) side light fuses are located in the engine bay by the battery....you ll need to remove the battery cover lid and surround to gain access.... Edited February 10, 2015 by buster Quote
Keyser Posted February 10, 2015 Posted February 10, 2015 Which light one is in the footwell then - interior? You should know where all the fuses are I blew most of yours for you once 1 Quote
GT Driver Posted February 10, 2015 Author Posted February 10, 2015 Thanks for the responses lads! Got to the bottom of it. 10a fuse was blown - no 71 I think. It was in the fuse box behind the battery (a pain to get to!) pulled a spare fuse out of the drivers footwell fuseboz and popped it in- all sorted. Only noticed the fuse puller after I'd be prying them out with my fingers lol! Quote
