joe8279 Posted February 1, 2015 Posted February 1, 2015 Hi All Does anyone know how to turn the engine warning light off? CEL light I think it is known as. I have a 03 plate 350Z I read the post below: http://www.350z-uk.com/topic/45371-cel-light-on-safe-to-drive/page__hl__+check%20+engine%20+light#entry685768 Not too sure if the engine needs to be running or not but I cant see to get it to work. Any ideas. Cheers Quote
Neilp Posted February 1, 2015 Posted February 1, 2015 Have you checked the fault codes to see what the issue is? The above link is timing critical and you must get it spot on. You will normally do it with the engine off as you need to use the key to start the sequence etc. Quote
joe8279 Posted February 1, 2015 Author Posted February 1, 2015 Cheers for the quick reply - I cant even get the sequence to work to see what the code is Must be that I am not getting the timings of the sequence correct will try again Quote
Neilp Posted February 1, 2015 Posted February 1, 2015 You really need to use a stop watch. Its a bit of a PITA. There may be somebody round bout who can help with a reader. Is your car UK or an Import? Quote
joe8279 Posted February 1, 2015 Author Posted February 1, 2015 my car is a UK - v low mileage one owner (b4 me) and has 28K on the clock fully serviced - so I am surprised the light has come on . Quote
Neilp Posted February 1, 2015 Posted February 1, 2015 It could be for a variety of things. I'd keep at the pedal dance or change the title of the thread to something that people from your area may pick up on and offer to come round to ur gaff and help out. I'd be driving carefully in the mean time, and avoiding driving if possible. Last thing you want to do is damage it. Quote
cs2000 Posted February 2, 2015 Posted February 2, 2015 Where are you based? Maybe a member close by with a code reader if you can't get the pedal dance to work. Quote
Mark@Abbey m/s Posted February 2, 2015 Posted February 2, 2015 Hi, drop down to us in surrey (junction 6 M25) we can read the ECU and help give you any information to sort the issue causing the CEL. thanks Quote
