Garyt350z Posted December 6, 2014 Posted December 6, 2014 Looking at simple but effective performance mods and have already done air in take and exhaust Mods, so now looking at throttle body and controller. What are the pros and cons of a larger diameter throttle body? Is it a simple swap and are there other things like software changes needed to run it? It just seems like simple money to increase air intake. Or is it a gimmick unless you have forced induction? Quote
Garyt350z Posted December 6, 2014 Author Posted December 6, 2014 I should also add that I have a plenum spacer, incase that alters the reason to purchase or to ignore! Quote
Wasso Posted December 6, 2014 Posted December 6, 2014 I'm probably not the best to answer, but if you enlarge the TB surely the Plenum would need changing also. I'm presuming it's diameter change that we're talking. 1 Quote
CrustyCrab Posted December 6, 2014 Posted December 6, 2014 I think Ian's right there. Also unless you get an uprev your car will negate any advantages of having it. If it was forced induction could make a difference though 1 Quote
Tricky-Ricky Posted December 6, 2014 Posted December 6, 2014 Pointless IMO apart from needing a redesigned plenum (as tis is one of the primary limits on making power on the VQ motor) size isn't always the answer to making power on an N/A motor, and its already rather a convoluted path with this engine, Not essential on FI either as the airflow is under pressure anyway. Quote
Jetpilot Posted December 6, 2014 Posted December 6, 2014 I put a large diameter throttle body on my Rx7, was without doubt the worst money i had ever spent on it, i know thats generalising but for a fi car i saw no noticeable hp gains, idle was erratic and trying to drive on part throttle was interesting to say the least, great on wot throttle, but anything in between was shocking. Quote
