How on Earth do I remove this?
So I am currently upside down in the passenger footwell trying to access the screw to remove this panel. Is dark, cold and blood is rushing to my head - needless to say patience is wearing thin
Thanks
Which panel? The side panel on the center console or the panel beneath the pax side dashboard?
The side panel; managed to remove the drivers side as the screw was accessible however the passenger side isn't.
Ok did this last night in the dark
1. Do a google first as I am stoned on toffee apple cider
2. See 1.
3. Ok let me slap myself
4. Remove the curved step that runs along the sill pull gently from curved end and it will snap out
5. Remove the passenger side panel just pops out
6. Now it gets hazy. But I managed to pull down the lower dash easily enough to access the screw. Have a quick look as there may have been one screw. Can't remember . It's my age. If you have a cup holder there is a bolt that needs to come out if you want the panel off
7. Should be able to pop off the side console now. Make sure you recover the smal stud clip as its easy to miss
8. Reverse to refit
9. I thang yew
