Engine rebuilder near Swansea
redheadordead
Hi Guys
I have the Nissan Skyline 350GT and it looks as if I need the Oil Scraper Rings changing as I have started to burn oil, the guys at the Skyline forum suggested that someone here my be able to help or give advice
Only had the car 6 weeks so gutted, quote so far is 3.5k......
All help gratefully received
This warrants further investigation, burning oil can be a multitude of things, head gasket, valve guides, valve stem seals, rings etc etc
If the oil slinger rings are broken they may cause bore scoring so it's a bad idea to run it
Sorry I can't advise on anywhere in Swansea but I'm sure someone will be along soon
That's bad luck, hopefully it's something not too costly as it could work out cheaper sourcing a replacement engine
Good luck and :welcome:
Edited by GIXXERUK
