redheadordead Posted May 30, 2014 Share Posted May 30, 2014 Hi Guys I have the Nissan Skyline 350GT and it looks as if I need the Oil Scraper Rings changing as I have started to burn oil, the guys at the Skyline forum suggested that someone here my be able to help or give advice Only had the car 6 weeks so gutted, quote so far is 3.5k...... All help gratefully received Quote Link to comment Share on other sites More sharing options...
Rock_Steady Posted May 30, 2014 Share Posted May 30, 2014 Oil Scraper Rings? Are those piston rings? Or ringlands? have you done a compression test? Quote Link to comment Share on other sites More sharing options...
redheadordead Posted May 30, 2014 Author Share Posted May 30, 2014 They are the Piston rings (I think lol) I was advised a compression test would not identify the problem, had the Oil & Filter changed yesterday and clean & protect added to see if this helps, cheers for the reply Quote Link to comment Share on other sites More sharing options...
GIXXERUK Posted May 30, 2014 Share Posted May 30, 2014 (edited) This warrants further investigation, burning oil can be a multitude of things, head gasket, valve guides, valve stem seals, rings etc etc If the oil slinger rings are broken they may cause bore scoring so it's a bad idea to run it Sorry I can't advise on anywhere in Swansea but I'm sure someone will be along soon That's bad luck, hopefully it's something not too costly as it could work out cheaper sourcing a replacement engine Good luck and Edited May 30, 2014 by GIXXERUK Quote Link to comment Share on other sites More sharing options...
redheadordead Posted May 30, 2014 Author Share Posted May 30, 2014 Cheers guys, appreciate the replies Quote Link to comment Share on other sites More sharing options...
350zedd Posted May 30, 2014 Share Posted May 30, 2014 PM sent Quote Link to comment Share on other sites More sharing options...
evilscorp Posted May 30, 2014 Share Posted May 30, 2014 have a look inside your plenum for lots of oil, do you see smoke on start up/full throttle? might as well rule out the other things first. Quote Link to comment Share on other sites More sharing options...
