Hi,
I recently had a P0340 error on the camshaft sensor. At this time my windows started playing up (would work and then not work).
Now I've replaced the camshaft sensor I don't get any power to my windows. The relay isn't clicking on either side and I know the motors are ok because I replaced with new a couple of months ago.
I'm aware of the window reset procedure but I assume it'll only work if I've actually got some power going to them.
What should I do next, disconnect battery? Any help would be appreciated.
P.S. I haven't got the window lock on!
Cheers.
Err, have you followed the diagnostic flowchart in the service manual ?? .. I don't have fuse details to hand, but I'd start there, especially if BOTH windows aren't working?
Ok, just to let people know the outcome in case anyone suffers the same. I disconnected the switch from the arm rest area, relay started clicking away so there was a dodgy connection somewhere. Turns out the switch connection wasn't completely pushed together, so a simple bit of pressure and all good now.
If only you'd have come round to do it then ;) It was pouring down the day I asked the question so thought I'd ask whilst waiting for the weather to improve.
By the way, I'd had it investigated and bought replacement window motors only a couple of months before so thought the obvious would've been ok.
