jayrishi Posted March 24, 2014 Posted March 24, 2014 have a slight issue replaced window motor window now works but won't align up so when door is shut and window is rolled up there is a gap. any ideas?? Preferences § 1 2 3 4 5 6 7 8 9 0 - = Backspace Tab q w e r t y u i o p [ ] Return capslock a s d f g h j k l ; ' \ shift ` z x c v b n m , . / shift English Deutsch Español Français Italiano Polski Português РуÑÑкий alt alt Preferences Quote
Grundy Posted March 25, 2014 Posted March 25, 2014 Use the search or google 350z-uk Window Reset. There's a reset procedure - Lots of threads about this. Quote
evest Posted March 25, 2014 Posted March 25, 2014 I've found that when you do the reset procedure, it's best to do it with the door closed (or hold the door switch in) - if you try to reset with the door open the car kinda gets confused. Mine did anyway! Quote
chubbster Posted March 25, 2014 Posted March 25, 2014 1. Press & hold the window button in the down position. Keep pushing the button for 15 seconds after the window has opened completely. 2. Now, lift & hold the same button to shut the window, keeping the button held up for 15 seconds after the window has shut completely. Does that work? Quote
