Mine came on at the start of a journey yesterday and went off after about half an hour. I will check the pressures as a precaution but does anyone have experience of the warning going on and off? I'm wondering if it was a false return due to other factors (temperature maybe). Car has only 2k on the clock and hasn't had much use recently due to the weather. Cheers.
the pressure will change as you drive, so warming up, the pressure has returned to normal tolerances - need to be 35 when cold though
