top speedo trim removal
Have searched and cant find an answer as to how to remove the top trim off the speedo. Looks like it just clips on but probably isn't that simple :lol:
Anyone had it off?
Cheers
You have to remove the lower column cover off them first then the rear silver circles cover (one piece). After this think its the metal clock facia then the two sections come apart. That is from memory though so may be something I have missed :thumbs:
Yea, take while thing out and take it apart mate :)
If its for the dipping - I will have a spare one soon, so you don't need to worry about removing it until you come to mine to swap bits over :)
Excellent!
Ive just read a guide it says,
Remove lower trim panel
Undo 4 lower column screws
Pull cover off
Undo the screws that hold the speedo on and pull up the speedo
Disconnect cable remove speedo
10 mins apparently
There are 4x 10mm bolts that hold the speedo on and to get to them you need to pull the lower part of the dash (the part that contains the fuel lid release button etc.. It's just held on by a clip each sided). Then take the lower steering shroud off that is held on by 4 Philips screws. You need a fairly long screw drive to get the the back shroud screws, the binnacle has one electrical connector plug on it. It really is a 10 min job to take out, I haven't taken the binnacle to pieces so have no idea how easy/hard that is.
  • 3 months later...
