SiriusProjects Posted August 9, 2013 Posted August 9, 2013 Hi Guys, I'm wanting to get a new headunit and I'm sure I read somewhere on the forum that you should get one with 3 pre-outs, 1 for the fronts, 1 for the rears and one for the sub-woofer. Is that right? Cheers. Quote
spursmaddave Posted August 9, 2013 Posted August 9, 2013 Hi Guys, I'm wanting to get a new headunit and I'm sure I read somewhere on the forum that you should get one with 3 pre-outs, 1 for the fronts, 1 for the rears and one for the sub-woofer. Is that right? Cheers. Thats ideal yes 2xfront 2xrear 1xsub Quote
SiriusProjects Posted August 12, 2013 Author Posted August 12, 2013 Right, I have been on the incartec website and ordered the necessary leads for the new Alpine double din headunit I am getting. The headunit does have 3 pre-outs (Front/Rear/Subwoofer). I do have a query though. The image of the iso lead shows the red and white phonos for the fronts and the black and yellow phonos for the rears, but where is the phono connector for the subwoofer? I'm assuming it will plug into the pre-out port on the headunit with a phono connector? Am I missing something? Apologies if this question has already been answered elsewhere. Quote
spursmaddave Posted August 12, 2013 Posted August 12, 2013 From memory there are no rca's on the oem loom, the adapter adds them like you say red/white & black/yellow. I think you need to add an rca connector for the sub Quote
SiriusProjects Posted August 12, 2013 Author Posted August 12, 2013 Where about would an rca connector for the sub get wired in? Quote
un1eash Posted August 12, 2013 Posted August 12, 2013 If your using the Bose speakers and amp then you don't need to use the sub RCA's. The Bose sub takes its feed from the front and rear signal. Quote
SiriusProjects Posted August 12, 2013 Author Posted August 12, 2013 Thank you un1eash for that useful info. I did wonder whether that was the case as I am using the Bose speakers and amp. Quote
flamez Posted August 14, 2013 Posted August 14, 2013 If you're gonna use the bose speakers and amp it wont be that loud as the bose needs quite a high input. Alot of us mod the speaker output from the headunit into the rcas to make it louder, in which case you wont need to worry about pre outs for now. Quote
inspiral Posted September 11, 2013 Posted September 11, 2013 If you're gonna use the bose speakers and amp it wont be that loud as the bose needs quite a high input. I've got a Pioneer head with 4v pre outs and it drives the OEM amps plenty loud enough. I've also got a SOny head that I've tried too that does have 4v pre out and it works ok but doesn't quite go as loud as it should. Cheers Quote
