Headlight missing so bad it's an advisory on the MOT
Hi all,
I've got an 03 import from japan, the headlights are starting to crack and mist internally so I need some advise on how to resolve the issue.
This is definately an internal issue, I've TCUT the hell out of the outside with zero improvement. It's almost like the lacquer is coming off inside the lamps. It was only an advisory on the last MOT but fear it may end up being a major if I dont get it sorted.
I was looking into buying a pair from the US as this is the only real cheap way to replace headlamps, my only concern is the left\right alignment needed for UK roads.
I managed to dig up this thread
http://www.350z-uk.com/index.php?showtopic=19504
which shows how to adjuast the lights to stop the dazzle cause to drivers on the right. Am I right in assuming then that these lights will fit a 350z import?
Alternatively, is there anyway I can adjust a UK model headlight to the JDM connector? I assume Id have to remove the auto leveling (Why dont jap cars have this?).
Any advise on the subject is much appreciated.
"Headlight missing so bad it's an advisory on the MOT"
its always good to have a headlight for an MOT test :thumbs:
ha ha, misting... suprised it was only an advisory if it was missing. ok will drop Shaun1982 a message shortly.
look through his posts as well as he made a thread about this same issue
