jon.young Posted November 13, 2012 Posted November 13, 2012 Hi all, My import 02 plate, I've had a rebuild done as the rings were worn, and turntable out the bores are fine, But I still get 120psi, on the gauge, the oil is just below the full mark, I was just wondering if their is a different sensor in the jam cars for the Kpa dials than the psi, Quote
Keyser Posted November 13, 2012 Posted November 13, 2012 Not sure - is this an after market gauge or the OEM one? What oil is it and was it hot? Mine is over 100psi cold drops as she warms up. I would plug a stand alone oil pressure gauge in to be sure. Quote
jon.young Posted November 13, 2012 Author Posted November 13, 2012 Cold it sits at around 100psi, this is 10/40w oil, on a oem dial, but when warm and around 20/30psi if I rev it to around 3.5 k it goes to 120psi with no load on the engine Yeah I have been thinking of using a test unit to verify the oem gauges Quote
rodgeevans Posted November 13, 2012 Posted November 13, 2012 where are you based i have a 350z jdm dial in the garage or someone close to you may have similar if just to test if it the dials or some other problem Quote
jon.young Posted November 13, 2012 Author Posted November 13, 2012 I'm in Bristol, But I will ask one of the fitters in work if he has a oil pressure guage kicking around Quote
