Mikesding Posted August 22, 2012 Posted August 22, 2012 Is this normal? My driver side window drops 5mm or so when you open the door, and goes back up when you close it. The passenger side doesn't do this, it doesn't seem to be causing any problems to be fair but wondered if there was a problem? Quote
14N Posted August 22, 2012 Posted August 22, 2012 Try a window reset. Basically involves taking the door card off and depressing a button. Simples. Have a search in the guides. Quote
taffyjason Posted August 22, 2012 Posted August 22, 2012 my old garaged diagnosed this as a regulator problem, so after having a new one fitted, my present garaged said no, they did the re-set which fixed it for a while, but problem came back, turns out it was just a motor calibration that was needed! so i have a spare regulator now if you need one! Quote
Mikesding Posted August 22, 2012 Author Posted August 22, 2012 Cheers guys, my car is still under warranty might go down that route first then, if not will have a go at fixing myself Quote
