Passenger window not dropping on open
Is this normal? My driver side window drops 5mm or so when you open the door, and goes back up when you close it. The passenger side doesn't do this, it doesn't seem to be causing any problems to be fair but wondered if there was a problem?
Try a window reset. Basically involves taking the door card off and depressing a button. Simples.
Have a search in the guides. :thumbs:
my old garaged diagnosed this as a regulator problem, so after having a new one fitted, my present garaged said no, they did the re-set which fixed it for a while, but problem came back, turns out it was just a motor calibration that was needed!
so i have a spare regulator now if you need one!
