engine oil spec
Viper
the ramps are £2200 installed (they have to aligned, bolted down and wired up by the company) and lift about 1 metre, they do a set that go's to 1.7 metres but then you had to crouch underneath and you need a tall garage. Supplied 6"x6"x1" square rubber blocks on the jacking points were used
the concrete has been cut and the ramps are flush with the floor so you can just drive over them without knowing they are there. His garage isnt quite complete as there are ceramic tiles to be laid
my mate has a discount card for vauxhall, same spec oil go's in the VXR's, so 5 litres which they sell for £48 was £17, bargain
