Any 350z specialist garages? help fix eml sensor
Ok guys i am looking for a experianced 350z specialist garage who can fix my cars EML light issue.
My car has thrown fault codes since fitting cat back exhaust.
i have already changed driverside post cat lambda sensor but still im having following codes coming up:
P0037 ho2s heater control circuit low bank 1 sensor 2
P0057 ho2s heater control circuit low bank 2 sensor 2
P1031 ?
P1051 ?
My car is 04 plate Uk spec
Only mod is the y pipe/centre section/back box exhaust fitted
Cats are factory original
We have already resetted the codes but they keep returning.
Also already checked all connections which are fine.
before i start replacing all sensor which is going to cost arm and a leg and then find the problem is still not gone.
I am looking for a experianced 350z speaclist garage who will identify the actual problem as i think its unlikely all the sensors go at once.
I understand someone mentioned Abbey motorsport which is also a option but is there any other 350z specialist garages i should also consider?
idealy a garage who also stocks 02 sensor New/Used in stock
I am from west midlands and willing to travel reasonable distance
Thanks in advance
We could help - maybe a bit far though. We're about 30 mins south of Oxford. We've got lambda sensors in stock and have the appropriate diagnostic equipment.
  • 3 weeks later...
Finaly got the EML light problem sorted.
Took my car to Jez's garage (Horsham Development) today.
he narrowed the problem down to break in the wire of faulty loom.Got it sorted now.
Jez is true 350z specialist.
Finaly i can now enjoy driving my car :yahoo:
Thanks Jez :)
would love to but cant im working on Saturdays :bang:
Hope you guys have a good time and weather is good as it had been all last week
