  • 5 months later...
  • 2 months later...
If you let me know quickly I can add a JWT oil spacer to my delivery of JWT pop chargers due next week.
Should be around £120
Is the one you supply with the oil drain feature or without?
Can you get the AAM spacer Tarmac? I'm not sure I can mount a sensor in that spacer without drilling it out.
You would have to drill and tap the JWT spacer but if it's a temperature sensor your fitting, that wants to be in the oil flow from the engine for an accurate reading, ideally in a sandwich plate.
The Spacer will give you the extra oil capacity though. I have the JWT on mine and it takes 5.7Ltrs of oil. :thumbs:
Mr T, Could you add one for an HR engine please.
Yeah, shouldn't be an issue, will check stocks tonight - you want me to go ahead ?
I could but wouldn't be able to combine with current shipment.
If anyone wants a JWT then let me know sharpish :thumbs:
Chaps,
I can get these for a VERY good price so let me know if you're interested and have NOT already ordered it with Tarmac. Send me a PM.
Cheers.
