pathfinder123 Posted September 5, 2010 Posted September 5, 2010 I think that I have finally tracked down a noise that has been bugging me for some time. I found that I could stop it by throwing a coat over the Rear Strut Brace Cover. I think that the cover is rattling, but just to be sure I would like to remove it, and look inside for anything else that might be loose. I have had a look at the technical bulletins, but they seem to indicate virtually all of the rear trim must be removed to gain access to the strut. Is this so, or is there a simpler way in ? It's an 08 Coupe. Cheers S. Quote
pathfinder123 Posted September 6, 2010 Author Posted September 6, 2010 Nothing ? Out with the tin opener then.... S. Quote
DoogyRev Posted September 6, 2010 Posted September 6, 2010 Just done a quick search...... viewtopic.php?f=35&t=22320&hilit=rear+strut+remove Hope it helps Quote
pathfinder123 Posted September 6, 2010 Author Posted September 6, 2010 Many thanks... some good tips here. It looks like a trim removal tool would make the job much easier, so I will see if there are any on eBay. Cheers S. Quote
Husky Posted September 6, 2010 Posted September 6, 2010 Many thanks... some good tips here. It looks like a trim removal tool would make the job much easier, so I will see if there are any on eBay. Cheers S. trim removal tools should cost pennies, can pick them up from machine mart or something if i recall Quote
