alessandro Posted June 15, 2010 Posted June 15, 2010 Took the tyres off my old wheels today, got home and discovered that one of the tyres got damaged during the removal. Those are/were going to be my winter tyres but, can I still use them? Quote
Neilp Posted June 15, 2010 Posted June 15, 2010 if you could see my gfs car tyre then youd be worried. (it was me that kerbed it lol- hate driving in edinburgh) as long as you can see the metal you should be fine. Quote
350zStephen Posted June 15, 2010 Posted June 15, 2010 I would replace it just to be on the safe side mate. Skimping on a tyre is not worth if it blows on you at 70mph on the motorway. Quote
sm1ke 350Z Posted June 15, 2010 Posted June 15, 2010 id want some heavy discount on a new tyre from who ever removed it if you expressed you wanted to keep them, its a little hard to tell from that pic bend the side wall around alot make sure its not deeper then it appears and no cords are showing e.c.t (where it sits on the rim and meets the side wall) Quote
cookiemonster Posted June 15, 2010 Posted June 15, 2010 Any damage to the sidewall makes them illegal, not that its likely you would get caught. If your asking the question its probably worth getting a replacement as it will always play on your mind, look on ebay for the same tyre with roughly the same tread, thats what i did. Quote
sm1ke 350Z Posted June 15, 2010 Posted June 15, 2010 Any damage to the sidewall makes them illegal, not that its likely you would get caught. If your asking the question its probably worth getting a replacement as it will always play on your mind, look on ebay for the same tyre with roughly the same tread, thats what i did. i agree m8 best to replace but its not illegal or a mot failure inless the coords are showing Quote
alessandro Posted June 15, 2010 Author Posted June 15, 2010 Any damage to the sidewall makes them illegal, not that its likely you would get caught. If your asking the question its probably worth getting a replacement as it will always play on your mind, look on ebay for the same tyre with roughly the same tread, thats what i did. That is a good idea, they tyres got 7mm basically new Quote
