Radiator Drain, only 5 litres came out - help?
Hi all
I drained the rad yesterday, I was expecting 8.9 litres to drop out - only 5 came out and 5 went in.
I am guessing there is old fluid in the system still. I undid the air release on the water pipe, undid the drain plug on the bottom of the rad, then released rad cap. However it seems not all the fluid came out.
Has anyone any tips on getting a complete drain?
i'm sure i only purchased 5 litres, can't remember,
check the envy wewbiste on the service section, they sell the required amount, and its where i bought mine from and should tell you how much is needed/goes in
There are removable drain plugs on the side of the block but I tend not to drain completely as bleeding the system afterwards can become problematical. ;)
I opened the drain plug and filled the rad until fluid came out of the drain plug.
I have a feeling not all fluid came out as I did the drain on the ramps, I think I'll give it another go with the entire car raised so that it is level
Its due a coolant change, and only half the fluid came out
And how do you think Nissan do it ? ;)
Honestly mate draining the coolant fully is more bother than what it is worth.
You could always flush it out with a running hose. ;)
