Engine fault light is on + VDC OFF + SLIP light
I was recently driving along in my 350 which ive had for a couple of months and have never had a problem until suddenly whilst cruising on the motorway the engine fault light comes on and then the VDC OFF light and SLIP light keep popping up any suggestions as to what the probem could be and how to sort it?
many thanks
will
Might be a stupid question but what's the VDC Off light?
Is it the same as the ESP Off light?
will350:
Did you experience any loss of power around the time the CEL came on?
Is the CEL still on?
If so then get the code read before clearing ... :thumbs:
thanks for the replys guys the lights are still on and there is no loss in power as i just gave it a good thrashing to check but all seem to be working fine apart from these lights. may sound silly but how would i chck the code?
im going to reset the ecu and see what happens but if it comes on again im goin to take it to the garage any1 know how much it costs to get the fault code read and turned off?
just reset the ECU useing the guide procedures and it has worked a treat took me a couple of attempts because you've got to be spot on with the timings but just been out in the car all the lights are off and the car is quicker and more responsive on the throttle so im a very happy man right now haha cheers for the posts guys :teeth::teeth::teeth::teeth:
